Ir para o conteúdo principal
Samsung Radiant360 R3 Wireless Module Replacement
O que você precisa
  1. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: passo 1, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: passo 1, imagem 2 %32 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Setup Button and USB Module: passo 1, imagem 3 %32
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Samsung Radiant360 R3 Wireless Module Replacement: passo 2, imagem 1 %32
    • Remove the bottom shell from the speaker.
  3. Samsung Radiant360 R3 Wireless Module Replacement: passo 3, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 3, imagem 2 %32
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Samsung Radiant360 R3 Wireless Module Replacement: passo 4, imagem 1 %32
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Samsung Radiant360 R3 Wireless Module Replacement: passo 5, imagem 1 %32
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: passo 6, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement, Wireless Module: passo 6, imagem 2 %32
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Samsung Radiant360 R3 Wireless Module Replacement: passo 7, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 7, imagem 2 %32
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Samsung Radiant360 R3 Wireless Module Replacement: passo 8, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 8, imagem 2 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 8, imagem 3 %32
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  9. Samsung Radiant360 R3 Wireless Module Replacement: passo 9, imagem 1 %32
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  10. Samsung Radiant360 R3 Wireless Module Replacement: passo 10, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 10, imagem 2 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 10, imagem 3 %32
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  11. Samsung Radiant360 R3 Wireless Module Replacement: passo 11, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 11, imagem 2 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 11, imagem 3 %32
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  12. Samsung Radiant360 R3 Wireless Module Replacement: passo 12, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 12, imagem 2 %32
    • Pry the two halves of the body open using a metal spudger.
  13. Samsung Radiant360 R3 Wireless Module Replacement: passo 13, imagem 1 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 13, imagem 2 %32 Samsung Radiant360 R3 Wireless Module Replacement: passo 13, imagem 3 %32
    • Remove the plugs located topmost right and closest to the bottom in picture.
  14. Samsung Radiant360 R3 Wireless Module Replacement: passo 14, imagem 1 %32
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  15. Samsung Radiant360 R3 Wireless Module Replacement: passo 15, imagem 1 %32
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
Conclusão
Fadi Alzammar
Membro desde: 04/22/18
782 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S25-G18, Maness Spring 2018 Membro de Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 271
