Introdução
This guide will take you through the process of removing the bottom of the speaker, seperating the shell of the enclosure, and accessing the wireless module for removal.
O que você precisa
Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
Remove the four 10mm long screws with the Phillips #1 screwdriver.
Remove the two 12mm long screws with the Phillips #1 screwdriver.
Unplug white plug connected to the green circuit board.
