Introdução
This guide will take you through the process of removing the bottom of the speaker, separating the shell of the enclosure, and accessing the motherboard for removal.
Peças
Não são necessárias peças.
  1. Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers. Remove the four 10mm long screws with the Phillips #1 screwdriver. Remove the four 10mm long screws with the Phillips #1 screwdriver.
    • Flip the device so that the bottom of the device is facing you. Remove these feet with a pair of tweezers.
    • Remove the four 10mm long screws with the Phillips #1 screwdriver.
  2. Remove the bottom shell from the speaker.
    • Remove the bottom shell from the speaker.
  3. Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger. Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
    • Remove the connector from the board by pressing down on the center tab while nudging the connector away with a spudger.
    • Be careful not to pull directly on the wires or apply too much pressure, or you risk breaking the connector.
  4. Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
    • Remove the two 10mm long screws from the board utilizing the Phillips #1 screwdriver.
  5. Use a spudger to press the plastic tab away from the board until the board pops up.
    • Use a spudger to press the plastic tab away from the board until the board pops up.
    • Remove the board with the USB module from the device.
  6. Remove the two 12mm long screws with the Phillips #1 screwdriver. Unplug white plug connected to the green circuit board.
    • Remove the two 12mm long screws with the Phillips #1 screwdriver.
    • Unplug white plug connected to the green circuit board.
  7. Remove the four 12mm long screws with the Phillips #1 screwdriver. Remove the cover, and slide the cord through the hole.
    • Remove the four 12mm long screws with the Phillips #1 screwdriver.
    • Remove the cover, and slide the cord through the hole.
  8. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  9. Remove rubber covers covering the screws with pair of tweezers. Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver. Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
    • Remove rubber covers covering the screws with pair of tweezers.
    • Remove the six 12mm screws that are under the rubber covers with the Phillips #1 screwdriver.
  10. Remove the unscrewed cover as much as possible.
    • Remove the unscrewed cover as much as possible.
    • It is very difficult to get plugs at the end of the cord through the cover without breaking, so just slide to the edge.
  11. Push the body out through the outer shell of device. Carefully push the ring attached to the cable through the shell. Carefully push the ring attached to the cable through the shell.
    • Push the body out through the outer shell of device.
    • Carefully push the ring attached to the cable through the shell.
  12. Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver. Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver. Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
    • Remove the eight 12mm long screws around the body with the Phillips #1 screwdriver.
  13. Pry the two halves of the body open using a metal spudger. Pry the two halves of the body open using a metal spudger.
    • Pry the two halves of the body open using a metal spudger.
  14. Remove the plugs located topmost right  and closest to the bottom in picture. Remove the plugs located topmost right  and closest to the bottom in picture. Remove the plugs located topmost right  and closest to the bottom in picture.
    • Remove the plugs located topmost right and closest to the bottom in picture.
  15. Remove the four 12mm long  screws with the Phillips #1 screwdriver .
    • Remove the four 12mm long screws with the Phillips #1 screwdriver .
  16. Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Unscrew the four 8mm screws on the side of the motherboard with the Phillips #1 screwdriver .
    • Remove the Wireless Module from the device.
  17. Disconnect the plug in the device. Disconnect the plug in the device.
    • Disconnect the plug in the device.
  18. Slide the subwoofer out of the speaker.
    • Slide the subwoofer out of the speaker.
  19. Disconnect the six plugs on the motherboard. Disconnect the six plugs on the motherboard.
    • Disconnect the six plugs on the motherboard.
  20. Remove the ZIF cable.
    • Remove the ZIF cable.
    • Pull up the tab with a spudger, and life the cable.
  21. Remove the four 12mm screws with the Phillips #1 screwdriver . Remove the motherboard from the device.
    • Remove the four 12mm screws with the Phillips #1 screwdriver .
    • Remove the motherboard from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Fadi Alzammar
782 reputação
5 Guides authored
Equipe
Cal Poly, Team S25-G18, Maness Spring 2018 Membro de Cal Poly, Team S25-G18, Maness Spring 2018
CPSU-MANESS-S18S25G18
4 Membros
5 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Todo: 130
