Ir para o conteúdo principal
Samsung RS25J500DSR LED Light Replacement
  1. Samsung RS25J500DSR LED Light Replacement, LED light: passo 1, imagem 1 %32 Samsung RS25J500DSR LED Light Replacement, LED light: passo 1, imagem 2 %32 Samsung RS25J500DSR LED Light Replacement, LED light: passo 1, imagem 3 %32
    • Disconnect the refrigerator for the electrical outlet box.
    • Remove the cover that protects the LED light.
  2. Samsung RS25J500DSR LED Light Replacement: passo 2, imagem 1 %32 Samsung RS25J500DSR LED Light Replacement: passo 2, imagem 2 %32 Samsung RS25J500DSR LED Light Replacement: passo 2, imagem 3 %32
    • Disconnect the damaged light from the connection.
  3. Samsung RS25J500DSR LED Light Replacement: passo 3, imagem 1 %32 Samsung RS25J500DSR LED Light Replacement: passo 3, imagem 2 %32 Samsung RS25J500DSR LED Light Replacement: passo 3, imagem 3 %32
    • Remove the damaged LED light to insert the new one on the connection.
    • Be careful not to damage the clip from the connection when removing the LED light.
  4. Samsung RS25J500DSR LED Light Replacement: passo 4, imagem 1 %32 Samsung RS25J500DSR LED Light Replacement: passo 4, imagem 2 %32 Samsung RS25J500DSR LED Light Replacement: passo 4, imagem 3 %32
    • To connect the new LED light, clip it onto the connector.
    • After connecting the new LED strip reconnect the refrigerator to see if the light is working.
Conclusão
Kimberlyne Barrios
Membro desde: 10/23/20
109 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 24
Ao todo: 2,524
