Ir para o conteúdo principal
Samsung RF4287HABP Ice Maker Repair
O que você precisa
  1. Samsung RF4287HABP Ice Maker Repair, Samsung RF4287HABP Ice Maker Repair: passo 1, imagem 1 %32
    • Push the “Energy Saver” button and “Fridge” button for about 8 seconds.
  2. Samsung RF4287HABP Ice Maker Repair: passo 2, imagem 1 %32
    • After you hear a beep, continue to press the “Energy Saver” button until “Fd” appears.
    • The refrigerator will continue to beep for approximately 20 minutes until the ice maker has defrosted.
    • Unplug the refrigerator before beginning step 3.
  3. Samsung RF4287HABP Ice Maker Repair: passo 3, imagem 1 %32 Samsung RF4287HABP Ice Maker Repair: passo 3, imagem 2 %32 Samsung RF4287HABP Ice Maker Repair: passo 3, imagem 3 %32
    • Take the ice maker tray out of the icebox and place it in the sink to melt the remaining ice off.
  4. Samsung RF4287HABP Ice Maker Repair: passo 4, imagem 1 %32
    • Attempt to scrape any ice out of the icebox and defrost the remaining ice with a hairdryer or heat gun.
    • Use caution when applying heat. Excessive heat may cause the plastic to warp or melt, which could cause fit issues during installation.
  5. Samsung RF4287HABP Ice Maker Repair: passo 5, imagem 1 %32 Samsung RF4287HABP Ice Maker Repair: passo 5, imagem 2 %32
    • Unscrew the 0.05 mm screw on the left side panel inside the icebox with a Phillips #0 screwdriver.
  6. Samsung RF4287HABP Ice Maker Repair: passo 6, imagem 1 %32 Samsung RF4287HABP Ice Maker Repair: passo 6, imagem 2 %32
    • Carefully detach the plug connected to the thick white tube located to the left in the back of the icebox.
  7. Samsung RF4287HABP Ice Maker Repair: passo 7, imagem 1 %32 Samsung RF4287HABP Ice Maker Repair: passo 7, imagem 2 %32
    • Press the lever down and slide the ice maker forward at the very top of the icebox.
    • If the lever is stuck, it could be from the remaining ice in your ice maker.
  8. Samsung RF4287HABP Ice Maker Repair: passo 8, imagem 1 %32
    • Take out the ice tray and place it in the sink. Use a hairdryer to defrost the ice tray completely.
    • Reinsert and reconnect all the parts of the icemaker.
  9. Samsung RF4287HABP Ice Maker Repair: passo 9, imagem 1 %32
    • Plug the refrigerator back into the electrical outlet.
    • Press and hold the restart button located on the top of the ice maker beside the lever.
  10. Samsung RF4287HABP Ice Maker Repair: passo 10, imagem 1 %32
    • Unplug and plug the refrigerator if you do not hear a sound from the ice maker. Press and hold the restart button again until you hear water draining into the ice maker.
Conclusão
Uma outra pessoa concluiu este guia.
Madisyn
Membro desde: 09/30/21
208 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 100
Duração total: 4,216
