Introdução
HDD may need to be replaced if it is damaged or not working properly. Also upgrading to Solid State Drive (SSD) or a bigger capacity of HDD requires this replacement guide.
O que você precisa
Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
Carefully remove the back panel..
Quase terminado!
Conclusão
