Ir para o conteúdo principal
Samsung RC512 Cooling Fan/Heat Sink Replacement
O que você precisa
  1. Samsung RC512 Cooling Fan/Heat Sink Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down.
  2. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 2, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 2, imagem 2 %32
    • Locate two notches above the battery.
    • Slide both battery locking notches to either side to remove the battery.
    • Pull the battery out.
  3. Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: passo 3, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: passo 3, imagem 2 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement, Back Panel: passo 3, imagem 3 %32
    • Using the Phillips #0 screwdriver, unscrew the one 5mm screw.
    • Using the blue plastic opening tools, wedge one in between the back panel and the laptop.
    • Carefully remove the back panel..
  4. Samsung RC512 Cooling Fan/Heat Sink Replacement, HDD: passo 4, imagem 1 %32
    • Carefully lift the HDD up using plastic opening tool.
  5. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 5, imagem 1 %32
    • Grab the HDD and connector.
    • Carefully pull the HDD away from the connector.
  6. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 6, imagem 1 %32
    • Take out the HDD and leave the connector in the laptop
  7. Samsung RC512 Cooling Fan/Heat Sink Replacement, Optic Drive: passo 7, imagem 1 %32
    • Remove the 4mm Phillips #0 screw using a Phillips #0 screwdriver.
  8. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 8, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 8, imagem 2 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 8, imagem 3 %32
    • Use the spudger or fingers to gently pull the optical drive out.
    • Slide the optic drive away from the laptop.
  9. Samsung RC512 Cooling Fan/Heat Sink Replacement, Cooling Fan/Heat Sink: passo 9, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement, Cooling Fan/Heat Sink: passo 9, imagem 2 %32
    • Remove the eight 5mm Phillips #0 screws using a Phillips #0 driver.
    • Also remove the three 5mm Phillips #0 using a Phillips #0 driver.
  10. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 10, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 10, imagem 2 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 10, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove three bottom dark covers using tweezers.
    • Remove three 10mm Phillips #0 screws using Phillips #0 driver.
  11. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 11, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 11, imagem 2 %32
    • Insert a plastic opening tool into the back cover and the housing of the body.
    • Use the plastic opening tool to pop open the clamps that hold the casing onto the back cover.
    • Work your way around the all sides to completely take off the back cover.
    • You may use your fingers to help remove the cover.
    • Carefully lift the back cover. Do not use excessive force to lift it. If it feels like it will not pull up, make sure all the screws have been taken out.
  12. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 12, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 12, imagem 2 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 12, imagem 3 %32
    • Remove two 5mm Phillips #8 screw using a phillips #0 screwdriver.
    • Gently pull out the connector from the motherboard.
  13. Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 13, imagem 1 %32 Samsung RC512 Cooling Fan/Heat Sink Replacement: passo 13, imagem 2 %32
    • Remove the six 5mm Phillips #0 screw using a Phillips #0 screwdriver.
    • Gently lift the cooling fan and heat sink to take them off.
    • Heat sink might be hot right after the laptop is shutdown.
Conclusão
Uma outra pessoa concluiu este guia.
jando
Membro desde: 09/15/16
896 Reputação
Autoria de 8 guias
Equipe
USF Tampa, Team 18-2, Blackwell Fall 2016 Membro de USF Tampa, Team 18-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G2
Membros da 4
Autoria de 8 guias
Um comentário
Thanks for the graphics. But you missed 3 screws under the battery compartment.
Doing all of this really helped... before, my laptop would just turn off randomly. I'm thinking this was because of overheating.
After this, it hasn't shut down yet.
thank you.
gary.crump - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,313
