Ir para o conteúdo principal
Samsung Propel SIM Card Replacement
  1. Samsung Propel SIM Card Replacement, SIM Card: passo 1, imagem 1 %32 Samsung Propel SIM Card Replacement, SIM Card: passo 1, imagem 2 %32
    • On the back of the phone locate the back panel.
    • Remove the back panel.
    • Then locate the battery, remove the battery. You can set it to the side for now.
  2. Samsung Propel SIM Card Replacement: passo 2, imagem 1 %32 Samsung Propel SIM Card Replacement: passo 2, imagem 2 %32
    • Find the spot for the SIM Card; on the bottom right as seen in the picture.
    • Then remove the old sim card by sliding it out.
    • Now you can insert a new sim card in slot where the old one was.
  3. Samsung Propel SIM Card Replacement: passo 3, imagem 1 %32
    • Finally, insert the battery back to its original location.
    • Then place the back panel.
Conclusão
James Cote
Membro desde: 11/05/15
322 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-4, Bhusal Fall 2015 Membro de UMass Dartmouth, Team 1-4, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G4
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 355
