Ir para o conteúdo principal
Samsung Powerbot R9250 Battery Replacement
O que você precisa
  1. Samsung Powerbot R9250 Battery Replacement, Battery: passo 1, imagem 1 %32
    • On the bottom of the bot, locate the battery lid along the curved edge of the bot.
  2. Samsung Powerbot R9250 Battery Replacement: passo 2, imagem 1 %32 Samsung Powerbot R9250 Battery Replacement: passo 2, imagem 2 %32
    • Unscrew each of the two screws and remove the lid to expose the battery.
  3. Samsung Powerbot R9250 Battery Replacement: passo 3, imagem 1 %32
    • Follow the wires to find the small white box next to the battery.
  4. Samsung Powerbot R9250 Battery Replacement: passo 4, imagem 1 %32
    • On the side of the white box facing the battery, find the rigid tab.
  5. Samsung Powerbot R9250 Battery Replacement: passo 5, imagem 1 %32 Samsung Powerbot R9250 Battery Replacement: passo 5, imagem 2 %32 Samsung Powerbot R9250 Battery Replacement: passo 5, imagem 3 %32
    • Push this tab into the white box, and pull the wires up. This releases the wire from the white box, allowing you to fully remove the battery.
Conclusão
Ethen Sanchez
Membro desde: 01/24/17
552 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 10-3, Banghart Winter 2017 Membro de Cal Poly, Team 10-3, Banghart Winter 2017
CPSU-BANGHART-W17S10G3
Membros da 3
Autoria de 10 guias
4 comentários
This is what I needed to know. You are my life saver.
thank you.
Akiko Ohkawa - Responder
How do you know it’s time for a battery replacement? Mine starts up fine, but after 5 minutes suction drops to lowest setting.
James Morgan - Responder
Where can we a get a replacement battery, I could not find one anywhere.
Hari Krishna Gaddipati - Responder
I am looking for one also!
Julie Miller -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 3,387
