Ir para o conteúdo principal
Samsung Portable Dualband Tri-Mode External Speaker Replacement
O que você precisa
  1. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Battery: passo 1, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Antenna: passo 2, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Antenna: passo 2, imagem 2 %32
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 3, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 3, imagem 2 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 3, imagem 3 %32
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: passo 4, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: passo 4, imagem 2 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: passo 4, imagem 3 %32
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: passo 5, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: passo 5, imagem 2 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: passo 5, imagem 3 %32
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: passo 6, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: passo 6, imagem 2 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: passo 6, imagem 3 %32
    • Locate the back plate of the phone. Turn the back plate over to view the inside.
    • Remove the 2 mm screw from the top of the inner back casing of the phone.
  7. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 7, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 7, imagem 2 %32
    • With the flat head screwdriver, remove the external speaker unit.
  8. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 8, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 8, imagem 2 %32
    • Take the external speaker unit and turn it over.
    • Remove the black rubber casing.
  9. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 9, imagem 1 %32 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 9, imagem 2 %32
    • Use tweezers to remove the external speaker from the small unit.
Conclusão
Barbara
Membro desde: 03/26/14
413 Reputação
Autoria de 4 guias
Equipe
Clemson, Team 6-2, Benson Spring 2014 Membro de Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 245
