Ir para o conteúdo principal
Samsung POWERbot VR9000 Powerbrush Replacement
  1. Samsung POWERbot VR9000 Powerbrush Replacement, Powerbrush: passo 1, imagem 1 %32 Samsung POWERbot VR9000 Powerbrush Replacement, Powerbrush: passo 1, imagem 2 %32
    • Turn off the emergency switch located at the bottom right of the POWERbot.
  2. Samsung POWERbot VR9000 Powerbrush Replacement: passo 2, imagem 1 %32 Samsung POWERbot VR9000 Powerbrush Replacement: passo 2, imagem 2 %32
    • Press the two yellow tabs immediately below the POWERbrush.
  3. Samsung POWERbot VR9000 Powerbrush Replacement: passo 3, imagem 1 %32 Samsung POWERbot VR9000 Powerbrush Replacement: passo 3, imagem 2 %32
    • Lift the brush cover, indicated by the yellow strip located above the yellow tabs.
  4. Samsung POWERbot VR9000 Powerbrush Replacement: passo 4, imagem 1 %32 Samsung POWERbot VR9000 Powerbrush Replacement: passo 4, imagem 2 %32
    • Remove the power brush starting with the unhinged right side of the brush.
Conclusão
Harrison Fugate
Membro desde: 04/24/17
102 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S15-G3, Banghart Spring 2017 Membro de Cal Poly, Team S15-G3, Banghart Spring 2017
CPSU-BANGHART-S17S15G3
Membros da 4
Autoria de 14 guias
2 comentários
The brush is wobbly in position. Is there an insert on the right side of the brush at the bearing. This position, the bearing look too small for the opening of the cover and the upper plastic.
Charlie nguyen - Responder
Did you lose the rubber cover/ washer that goes over the bearing? You can replace it from Samsung if you did.
hawkswhispertwh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 2,223
