Ir para o conteúdo principal
Samsung POWERbot R7070 Power Brush Replacement
  1. Samsung POWERbot R7070 Power Brush Replacement, Brush: passo 1, imagem 1 %32
    • Flip the device over to access the bottom of the vacuum with the brush compartment positioned close to you.
  2. Samsung POWERbot R7070 Power Brush Replacement: passo 2, imagem 1 %32
    • Slide up on the two yellow sliding tabs to unlock the brush compartment.
  3. Samsung POWERbot R7070 Power Brush Replacement: passo 3, imagem 1 %32 Samsung POWERbot R7070 Power Brush Replacement: passo 3, imagem 2 %32 Samsung POWERbot R7070 Power Brush Replacement: passo 3, imagem 3 %32
    • Press down on the outer edge of the brush cover to tilt the brush cover up. Grab the newly exposed inner edge and lift out the brush cover.
  4. Samsung POWERbot R7070 Power Brush Replacement: passo 4, imagem 1 %32 Samsung POWERbot R7070 Power Brush Replacement: passo 4, imagem 2 %32
    • Pull up the left side of the brush and lift out of the brush compartment.
    • When replacing the brush, the square peg on the right end of the brush must be correctly oriented with the square hole on the right end of the brush compartment.
Conclusão
4 outras pessoas executaram este guia.
Equipe
CSU Fullerton, Team S2-G8, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G8, Bruce Fall 2017
CSUF-BRUCE-F17S2G8
3 Membros
Autoria de 10 guias
5Comentários do guia
How often should the power VR 7000 series self cleaning powerbrush be replace?
Kip Williams - Responder
Hello, where could I find a replacement brush for this model?
Haitham - Responder
Without a part number, I cannot find a replacement brush.
David Williams - Responder
Your brush motor is broken and you can't find it?
engine model: RS395 - 2175 metal case,
fixxer - Responder
Hi, Can anyone send me some info on a part number and where to get a replacement brush ~ Samsung POWERbot R7070 Power Brush Replacement?
Thanks much
Kokko Walker - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 24
Ao todo: 4,233
