Ir para o conteúdo principal
Samsung PL200 SD card Replacement
  1. Samsung PL200 SD card Replacement, SD card: passo 1, imagem 1 %32 Samsung PL200 SD card Replacement, SD card: passo 1, imagem 2 %32
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
    • Once opened, the SD card should be visible.
  2. Samsung PL200 SD card Replacement: passo 2, imagem 1 %32 Samsung PL200 SD card Replacement: passo 2, imagem 2 %32
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector.
    • This will cause the SD card to raise up enough to allow you to grab it with your fingers.
    • Use your fingers to remove the old SD card.
  3. Samsung PL200 SD card Replacement: passo 3, imagem 1 %32 Samsung PL200 SD card Replacement: passo 3, imagem 2 %32
    • Insert the new SD card into the SD card slot.
    • Make sure to push it down all the way until it clicks and remains flush with battery.
    • Close the battery/SD card compartment.
Conclusão
Uma outra pessoa concluiu este guia.
Jacob Presnell
Membro desde: 01/29/15
219 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 15-7, Shirley Winter 2015 Membro de Clemson, Team 15-7, Shirley Winter 2015
CLEM-SHIRLEY-W15S15G7
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 307
