Introdução
In the instance of a broken screen, many laptop users will consider their device useless and begin looking for an entirely new laptop. However, this issue can be remedied in a more cost effective way by installing a new screen to the laptop, which can be a quick and simple process if done correctly.
To ensure an efficient screen replacement of the Samsung Odyssey NP800G5M, use the steps listed in the following guide.
O que você precisa
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
Take the flat end of spudger and flip up the LCD wire connection locking mechanism.
Remove the LCD wire connection by pulling up on the tab until the cable is free.
5 outras pessoas executaram este guia.
