Ir para o conteúdo principal
Samsung Odyssey NP800G5M Fan Replacement
O que você precisa
  1. Samsung Odyssey NP800G5M Fan Replacement, Battery: passo 1, imagem 1 %32
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Fan Replacement: passo 2, imagem 1 %32 Samsung Odyssey NP800G5M Fan Replacement: passo 2, imagem 2 %32
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Fan Replacement: passo 3, imagem 1 %32 Samsung Odyssey NP800G5M Fan Replacement: passo 3, imagem 2 %32
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Fan Replacement: passo 4, imagem 1 %32 Samsung Odyssey NP800G5M Fan Replacement: passo 4, imagem 2 %32 Samsung Odyssey NP800G5M Fan Replacement: passo 4, imagem 3 %32
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Fan Replacement, Fan: passo 5, imagem 1 %32 Samsung Odyssey NP800G5M Fan Replacement, Fan: passo 5, imagem 2 %32 Samsung Odyssey NP800G5M Fan Replacement, Fan: passo 5, imagem 3 %32
    • Disconnect the fans from the motherboard by pulling the plugs away from their connectors.
    • Using the Phillips #0 screwdriver, remove the four 4.6mm screws.
    • Using the same screwdriver, unscrew the six screws surrounding the heat sink.
    • These screws cannot be removed from the device.
    • Remove the fan assembly from the device.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 1,256
