Introdução
Laptops overheating has been a prevalent problem since their conception. The usual culprit of this can be attributed to a broken or slow ventilation system. The Samsung Odyssey uses the HexaFlow cooling system to prevent overheating, but issues can still arise. This guide will show you how to replace the fan in your laptop.
O que você precisa
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
Disconnect the fans from the motherboard by pulling the plugs away from their connectors.
Using the Phillips #0 screwdriver, remove the four 4.6mm screws.
Using the same screwdriver, unscrew the six screws surrounding the heat sink.
Remove the fan assembly from the device.
4 outras pessoas executaram este guia.
