Introdução
If your Samsung Odyssey NP800G5M is not powering on or charging, it is most likely due to a faulty/dead battery. The battery can be replaced in a few simple steps. However, take the necessary precautions.
O que você precisa
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
5 outras pessoas executaram este guia.
