Ir para o conteúdo principal
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
O que você precisa
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: passo 1, imagem 1 %32
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 2, imagem 1 %32 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 3, imagem 1 %32 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 3, imagem 2 %32
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 4, imagem 1 %32 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 5, imagem 1 %32 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 5, imagem 2 %32 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 5, imagem 3 %32
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: passo 6, imagem 1 %32
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 7, imagem 1 %32
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: passo 8, imagem 1 %32
    • Pull the hard drive away from the cradle and remove it from the device.
Conclusão
2 comentários
Would you point out where the SSD slot would be?
aroyphillips - Responder
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 3,619
