Ir para o conteúdo principal
Samsung NX500 Screen Side Encasement Replacement
O que você precisa
  1. Samsung NX500 Screen Side Encasement Replacement, Battery: passo 1, imagem 1 %32 Samsung NX500 Screen Side Encasement Replacement, Battery: passo 1, imagem 2 %32
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Screen Side Encasement Replacement: passo 2, imagem 1 %32 Samsung NX500 Screen Side Encasement Replacement: passo 2, imagem 2 %32
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Screen Side Encasement Replacement: passo 3, imagem 1 %32
    • Pull out battery.
  4. Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: passo 4, imagem 1 %32 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: passo 4, imagem 2 %32 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: passo 4, imagem 3 %32
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Screen Side Encasement Replacement: passo 5, imagem 1 %32 Samsung NX500 Screen Side Encasement Replacement: passo 5, imagem 2 %32 Samsung NX500 Screen Side Encasement Replacement: passo 5, imagem 3 %32
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Screen Side Encasement Replacement: passo 6, imagem 1 %32 Samsung NX500 Screen Side Encasement Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Screen Side Encasement Replacement: passo 7, imagem 1 %32 Samsung NX500 Screen Side Encasement Replacement: passo 7, imagem 2 %32
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
Conclusão
carter grenewicz
Membro desde: 09/15/16
204 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 18-5, Blackwell Fall 2016 Membro de USF Tampa, Team 18-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G5
3 Membros
Autoria de 12 guias
1Comentário do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,014
