Ir para o conteúdo principal
Samsung NX3000 Back Case Replacement
O que você precisa
  1. Samsung NX3000 Back Case Replacement, Battery: passo 1, imagem 1 %32 Samsung NX3000 Back Case Replacement, Battery: passo 1, imagem 2 %32 Samsung NX3000 Back Case Replacement, Battery: passo 1, imagem 3 %32
    • Turn the camera upside down. Only remove the lens if you have to in order to access the battery compartment, as dust particles could easily enter the main body and fall onto the delicate sensor.
    • Slide the button to the left to open the battery compartment.
    • Push the blue button up to release the battery.
    • The battery is not shown in these photos.
  2. Samsung NX3000 Back Case Replacement, Lens Assembly: passo 2, imagem 1 %32 Samsung NX3000 Back Case Replacement, Lens Assembly: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the four 7.3 mm Phillips screws from the front of the lens assembly.
    • Remove the silver ring with tweezers.
  3. Samsung NX3000 Back Case Replacement: passo 3, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 3, imagem 2 %32
    • Use tweezers to remove the black plastic ring and small metal ring inside the lens assembly.
  4. Samsung NX3000 Back Case Replacement: passo 4, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 4, imagem 2 %32 Samsung NX3000 Back Case Replacement: passo 4, imagem 3 %32
    • Use tweezers to lift the pyramid screw and spring from the lens assembly.
  5. Samsung NX3000 Back Case Replacement, Back Case: passo 5, imagem 1 %32 Samsung NX3000 Back Case Replacement, Back Case: passo 5, imagem 2 %32
    • Remove the three 4.3 mm Phillips screws from the bottom of the camera.
    • Remove the 4.3 mm Phillips screw hiding inside the battery compartment.
  6. Samsung NX3000 Back Case Replacement: passo 6, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 6, imagem 2 %32
    • Remove the 4.2 mm Phillips screw from the left handgrip.
    • Remove the two 4.2 mm Phillips screws from the right handgrip.
  7. Samsung NX3000 Back Case Replacement: passo 7, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 7, imagem 2 %32
    • Use tweezers to remove the metal shield from the external flash mount.
  8. Samsung NX3000 Back Case Replacement: passo 8, imagem 1 %32
    • Remove the four 5 mm Phillips screws from the external flash mount .
  9. Samsung NX3000 Back Case Replacement: passo 9, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 9, imagem 2 %32
    • Remove the external flash mount.
  10. Samsung NX3000 Back Case Replacement: passo 10, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 10, imagem 2 %32
    • Slowly pull the bottom of the back case away from the camera.
    • Do not attempt to remove the back case as it is attached to the motherboard by a ribbon cable.
  11. Samsung NX3000 Back Case Replacement: passo 11, imagem 1 %32 Samsung NX3000 Back Case Replacement: passo 11, imagem 2 %32 Samsung NX3000 Back Case Replacement: passo 11, imagem 3 %32
    • Use the flat end of a spudger to pry the flat topped connector straight up from the motherboard.
    • Remove the back case.
Conclusão
3 outras pessoas executaram este guia.
Kelsea Weber
Membro desde: 11/12/15
20.691 Reputação
Autoria de 32 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 1,340
