Ir para o conteúdo principal
Samsung NX30 Screen Replacement
O que você precisa
  1. Samsung NX30 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Flip the camera over so that the bottom of the camera is up.
    • Push the battery switch towards the back of the camera.
  2. Samsung NX30 Screen Replacement: passo 2, imagem 1 %32 Samsung NX30 Screen Replacement: passo 2, imagem 2 %32
    • Locate the blue switch above the battery pack.
    • Slide the blue switch into the camera in the direction of the arrow on the switch. When the switch has been pushed in the battery will spring up.
  3. Samsung NX30 Screen Replacement: passo 3, imagem 1 %32
    • Pull the battery out.
  4. Samsung NX30 Screen Replacement, Screen: passo 4, imagem 1 %32 Samsung NX30 Screen Replacement, Screen: passo 4, imagem 2 %32 Samsung NX30 Screen Replacement, Screen: passo 4, imagem 3 %32
    • Unscrew the nine 4mm Phillips head screws surrounding the body of the camera. They are located on the bottom of the camera and both sides of the camera.
  5. Samsung NX30 Screen Replacement: passo 5, imagem 1 %32 Samsung NX30 Screen Replacement: passo 5, imagem 2 %32 Samsung NX30 Screen Replacement: passo 5, imagem 3 %32
    • Pull the viewer out from the camera and then up.
    • Unscrew the two black 4mm Phillips head screws under it.
  6. Samsung NX30 Screen Replacement: passo 6, imagem 1 %32 Samsung NX30 Screen Replacement: passo 6, imagem 2 %32
    • Once the screws are all removed, place the camera face down, with the screen facing up.
    • Pry open the body using the plastic opening tool.
    • Gently open the body.
  7. Samsung NX30 Screen Replacement: passo 7, imagem 1 %32 Samsung NX30 Screen Replacement: passo 7, imagem 2 %32
    • Then use the plastic opening tool to dislodge the Ribbon Cable, located near the top of the camera, from the Circuit Board.
    • The Ribbon Cable will be disconnected from the Circuit Board when you are done.
Conclusão
Uma outra pessoa concluiu este guia.
Julia Kilcup
Membro desde: 02/03/16
399 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team 1-4, Rose Winter 2016 Membro de UW Tacoma, Team 1-4, Rose Winter 2016
UWT-ROSE-W16S1G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 1,835
