Ir para o conteúdo principal
Samsung NX2000 Lens Assembly Replacement
O que você precisa
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 1 %32 Samsung NX2000 Lens Assembly Replacement, Lens Assembly: passo 1, imagem 2 %32
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
  2. Samsung NX2000 Lens Assembly Replacement: passo 2, imagem 1 %32 Samsung NX2000 Lens Assembly Replacement: passo 2, imagem 2 %32 Samsung NX2000 Lens Assembly Replacement: passo 2, imagem 3 %32
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
  3. Samsung NX2000 Lens Assembly Replacement: passo 3, imagem 1 %32 Samsung NX2000 Lens Assembly Replacement: passo 3, imagem 2 %32 Samsung NX2000 Lens Assembly Replacement: passo 3, imagem 3 %32
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
  4. Samsung NX2000 Lens Assembly Replacement: passo 4, imagem 1 %32 Samsung NX2000 Lens Assembly Replacement: passo 4, imagem 2 %32 Samsung NX2000 Lens Assembly Replacement: passo 4, imagem 3 %32
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
Conclusão
Uma outra pessoa concluiu este guia.
Katarina Raic
Membro desde: 02/09/16
288 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 7-4, Cheng Spring 2016 Membro de USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 905
