Ir para o conteúdo principal
Samsung NX2000 LCD Replacement
O que você precisa
  1. Samsung NX2000 LCD Replacement, LCD: passo 1, imagem 1 %32
    • First begin by flipping your camera upside down.
    • Remove the seven 4mm screws from indicated circles shown using a Y0 screwdriver. There are three on the bottom, and two on each side
    • Remember to store the screws in a secure place.
  2. Samsung NX2000 LCD Replacement: passo 2, imagem 1 %32 Samsung NX2000 LCD Replacement: passo 2, imagem 2 %32 Samsung NX2000 LCD Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool into the gab between the camera body and the back panel. Carefully pry open the camera and separate the back panel.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
  3. Samsung NX2000 LCD Replacement: passo 3, imagem 1 %32 Samsung NX2000 LCD Replacement: passo 3, imagem 2 %32 Samsung NX2000 LCD Replacement: passo 3, imagem 3 %32
    • Before taking it apart you'll have to detach the display ribbon cable.
    • Use a plastic opening tool, lift up the black strip to release the ribbon cable from the connector.
  4. Samsung NX2000 LCD Replacement: passo 4, imagem 1 %32 Samsung NX2000 LCD Replacement: passo 4, imagem 2 %32 Samsung NX2000 LCD Replacement: passo 4, imagem 3 %32
    • Separate the LCD half compartment of the camera from the main body.
  5. Samsung NX2000 LCD Replacement: passo 5, imagem 1 %32
    • Remove the four 1mm screws with the Y0 screwdriver.
  6. Samsung NX2000 LCD Replacement: passo 6, imagem 1 %32 Samsung NX2000 LCD Replacement: passo 6, imagem 2 %32 Samsung NX2000 LCD Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a plastic opening tool or tweezers to lift the green tape located on top of the LCD controller board.
    • Detach the two ribbon cables, by first lifting the black tab on top of the connector.
    • Pull the ribbon cables out of the connectors with tweezers or two fingers.
  7. Samsung NX2000 LCD Replacement: passo 7, imagem 1 %32 Samsung NX2000 LCD Replacement: passo 7, imagem 2 %32 Samsung NX2000 LCD Replacement: passo 7, imagem 3 %32
    • Place blue plastic spudger in between LCD screen and plastic surrounding.
    • Begin to lift up slowly, removing the LCD screen from the main frame.
  8. Samsung NX2000 LCD Replacement: passo 8, imagem 1 %32
    • The LCD screen is now separated form the main frame.
Conclusão
Maria Zamora
Membro desde: 02/09/16
155 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-4, Cheng Spring 2016 Membro de USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 1,130
