Ir para o conteúdo principal
Samsung NX2000 Battery Replacement
  1. Samsung NX2000 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the camera upside down with the lens facing you.
  2. Samsung NX2000 Battery Replacement: passo 2, imagem 1 %32
    • Locate the sliding latch on the right side of the camera and slide the latch to the left side to open up the battery compartment.
  3. Samsung NX2000 Battery Replacement: passo 3, imagem 1 %32
    • Locate the blue release lever holding the battery down. Slide the blue lever to the right to release the battery itself.
  4. Samsung NX2000 Battery Replacement: passo 4, imagem 1 %32
    • The battery will now slide up about an inch allowing the battery to be pulled out of the camera.
  5. Samsung NX2000 Battery Replacement: passo 5, imagem 1 %32
    • Insert the new battery with the arrow on the battery pointing into the camera. The red square indicates the location of the arrow.
Conclusão
Uma outra pessoa concluiu este guia.
David Edbom
Membro desde: 02/09/16
119 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 7-4, Cheng Spring 2016 Membro de USF Tampa, Team 7-4, Cheng Spring 2016
USFT-CHENG-S16S7G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 850
