Ir para o conteúdo principal
Samsung NX1000 LCD Replacement
O que você precisa
  1. Samsung NX1000 LCD Replacement, Removing the Back Panel: passo 1, imagem 1 %32
    • Locate the bottom panel of the camera.
    • Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
    • Push the screwdriver firmly into the screw so that the driver will not strip the screw.
  2. Samsung NX1000 LCD Replacement: passo 2, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 2, imagem 2 %32
    • Unscrew the three 4.5mm #000 Philips screws on the sides of the camera using the Philips #000 screwdriver.
  3. Samsung NX1000 LCD Replacement: passo 3, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 3, imagem 2 %32
    • Pry open the back panel using the metal spudger.
    • Do not completely separate the back panel from the camera. There is a ribbon on bottom left back corner underneath the buttons. The ribbon will hold the back panel to the camera. Do not jam the tool in this part or the ribbon will rip.
  4. Samsung NX1000 LCD Replacement: passo 4, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 4, imagem 2 %32
    • Open the two halves of the camera, taking care not to disturb the ribbon cable.
    • Do not completely separate the halves. The ribbon cable needs to be disconnected from the ZIF connection carefully as shown in the next step
  5. Samsung NX1000 LCD Replacement: passo 5, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 5, imagem 2 %32 Samsung NX1000 LCD Replacement: passo 5, imagem 3 %32
    • Remove the ribbon by lifting the grey tab on the ZIF connector with the metal spudger.
    • Push the ribbon out of its socket with the plastic opening tool.
  6. Samsung NX1000 LCD Replacement: passo 6, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 6, imagem 2 %32
    • Completely separate the back panel from the camera.
  7. Samsung NX1000 LCD Replacement, Back Panel Components: passo 7, imagem 1 %32 Samsung NX1000 LCD Replacement, Back Panel Components: passo 7, imagem 2 %32
    • Remove all five 3mm Philips #000 screws from the inside of the back panel using the Philips #000 Screwdriver.
  8. Samsung NX1000 LCD Replacement: passo 8, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 8, imagem 2 %32 Samsung NX1000 LCD Replacement: passo 8, imagem 3 %32
    • Lift up the grey tab on the ZIF connector with the spudger to remove the ribbon.
    • Using both thumbs push the ribbon out of the ZIF connection.
  9. Samsung NX1000 LCD Replacement: passo 9, imagem 1 %32
    • Use the metal spudger to pick the bottom of the plastic piece while simultaneously using your index finger to push down on the larger metal slab. This will cause the metal plate with the large ribbon to slide down and out of the plastic back panel.
    • Do not disconnect the blue ribbon.
  10. Samsung NX1000 LCD Replacement, LCD: passo 10, imagem 1 %32 Samsung NX1000 LCD Replacement, LCD: passo 10, imagem 2 %32 Samsung NX1000 LCD Replacement, LCD: passo 10, imagem 3 %32
    • Use a metal tool to pick on the sides of the metal plate to remove the plate from the plastic tabs.
  11. Samsung NX1000 LCD Replacement: passo 11, imagem 1 %32 Samsung NX1000 LCD Replacement: passo 11, imagem 2 %32
    • Separate the LCD from the back panel.
Conclusão
Yesenia
Membro desde: 01/22/15
717 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-13, Maness Winter 2015 Membro de Cal Poly, Team 20-13, Maness Winter 2015
CPSU-MANESS-W15S20G13
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,234
