Ir para o conteúdo principal
Samsung NX1 Back Cover Replacement
O que você precisa
  1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: passo 1, imagem 1 %32 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: passo 1, imagem 2 %32
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Back Cover Replacement: passo 2, imagem 1 %32 Samsung NX1 Back Cover Replacement: passo 2, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Back Cover Replacement, Back Cover: passo 3, imagem 1 %32 Samsung NX1 Back Cover Replacement, Back Cover: passo 3, imagem 2 %32 Samsung NX1 Back Cover Replacement, Back Cover: passo 3, imagem 3 %32
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Back Cover Replacement: passo 4, imagem 1 %32 Samsung NX1 Back Cover Replacement: passo 4, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Back Cover Replacement: passo 5, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Back Cover Replacement: passo 6, imagem 1 %32
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Back Cover Replacement: passo 7, imagem 1 %32 Samsung NX1 Back Cover Replacement: passo 7, imagem 2 %32 Samsung NX1 Back Cover Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Back Cover Replacement: passo 8, imagem 1 %32 Samsung NX1 Back Cover Replacement: passo 8, imagem 2 %32
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Back Cover Replacement: passo 9, imagem 1 %32 Samsung NX1 Back Cover Replacement: passo 9, imagem 2 %32 Samsung NX1 Back Cover Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
Conclusão
Uma outra pessoa concluiu este guia.
Hannah Patrick
Membro desde: 02/24/16
903 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-4, Leahy Spring 2016 Membro de USF Tampa, Team 1-4, Leahy Spring 2016
USFT-LEAHY-S16S1G4
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 1,092
