Ir para o conteúdo principal
Samsung NP900X4B Fan Replacement
O que você precisa
  1. Samsung NP900X4B Fan Replacement, Back Panel: passo 1, imagem 1 %32 Samsung NP900X4B Fan Replacement, Back Panel: passo 1, imagem 2 %32
    • First turn the computer over so you are looking at the back panel.
    • Next locate all ten Phillips #0 3.5mm screws on the back panel that are securing it down.
  2. Samsung NP900X4B Fan Replacement: passo 2, imagem 1 %32
    • Next remove all 3.5mm Phillips #0 screws shown in the previous step.
  3. Samsung NP900X4B Fan Replacement: passo 3, imagem 1 %32 Samsung NP900X4B Fan Replacement: passo 3, imagem 2 %32
    • After all screws are removed, lift up the back panel as shown.
  4. Samsung NP900X4B Fan Replacement, Fan: passo 4, imagem 1 %32 Samsung NP900X4B Fan Replacement, Fan: passo 4, imagem 2 %32
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  5. Samsung NP900X4B Fan Replacement: passo 5, imagem 1 %32
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  6. Samsung NP900X4B Fan Replacement: passo 6, imagem 1 %32 Samsung NP900X4B Fan Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  7. Samsung NP900X4B Fan Replacement: passo 7, imagem 1 %32
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Brian Miller
Membro desde: 10/17/18
333 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 Membro de UMass Dartmouth, Team S4-G6, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G6
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 175
