Ir para o conteúdo principal
Samsung NP900X4B Battery Replacement
O que você precisa
  1. Samsung NP900X4B Battery Replacement, Battery: passo 1, imagem 1 %32 Samsung NP900X4B Battery Replacement, Battery: passo 1, imagem 2 %32
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung NP900X4B Battery Replacement: passo 2, imagem 1 %32
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung NP900X4B Battery Replacement: passo 3, imagem 1 %32 Samsung NP900X4B Battery Replacement: passo 3, imagem 2 %32
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung NP900X4B Battery Replacement: passo 4, imagem 1 %32
    • Lift and pull out the battery.
Conclusão
Nathan LeBlanc
Membro desde: 10/17/18
109 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 Membro de UMass Dartmouth, Team S4-G6, Valliere Fall 2018
UMASSD-VALLIERE-F18S4G6
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 613
