Introdução
This guide provides detailed steps to remove and replace the device's Optical Drive in the Samsung NP700Z5AH device.
O que você precisa
Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
Using your fingers, grasp the ribbon cable connected to the optical drive and pull it straight out to disconnect it.
Quase terminado!
Conclusão
