Ir para o conteúdo principal
Samsung NP700Z5AH Battery Replacement
O que você precisa
  1. Samsung NP700Z5AH Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Battery Replacement: passo 2, imagem 1 %32 Samsung NP700Z5AH Battery Replacement: passo 2, imagem 2 %32 Samsung NP700Z5AH Battery Replacement: passo 2, imagem 3 %32
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Battery Replacement: passo 3, imagem 1 %32 Samsung NP700Z5AH Battery Replacement: passo 3, imagem 2 %32
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Battery Replacement: passo 4, imagem 1 %32 Samsung NP700Z5AH Battery Replacement: passo 4, imagem 2 %32
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Battery Replacement: passo 5, imagem 1 %32
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Battery Replacement: passo 6, imagem 1 %32 Samsung NP700Z5AH Battery Replacement: passo 6, imagem 2 %32
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
ifixit@distinctlydifferent.co.uk
Jacqueline - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 977
