Ir para o conteúdo principal
Samsung NP540U3C-A02UB Speaker Replacement
O que você precisa
  1. Samsung NP540U3C-A02UB Speaker Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Speaker Replacement: passo 2, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 2, imagem 2 %32
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Speaker Replacement: passo 3, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 3, imagem 2 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 3, imagem 3 %32
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Speaker Replacement: passo 4, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 4, imagem 2 %32
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Speaker Replacement: passo 5, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Speaker Replacement: passo 6, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 6, imagem 2 %32
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Speaker Replacement, Battery: passo 7, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement, Battery: passo 7, imagem 2 %32
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Speaker Replacement: passo 8, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 8, imagem 2 %32
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Speaker Replacement: passo 9, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 9, imagem 2 %32
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Speaker Replacement: passo 10, imagem 1 %32
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Speaker Replacement: passo 11, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 11, imagem 2 %32
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Speaker Replacement: passo 12, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 12, imagem 2 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 12, imagem 3 %32
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Speaker Replacement: passo 13, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 13, imagem 2 %32
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Speaker Replacement: passo 14, imagem 1 %32
    • Remove the battery from the laptop.
  15. Samsung NP540U3C-A02UB Speaker Replacement, Speaker: passo 15, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement, Speaker: passo 15, imagem 2 %32 Samsung NP540U3C-A02UB Speaker Replacement, Speaker: passo 15, imagem 3 %32
    • Using the plastic opening tool, gently release the connector for the speaker(s) you are replacing.
    • These will be found on opposite sides of where the battery was attached.
  16. Samsung NP540U3C-A02UB Speaker Replacement: passo 16, imagem 1 %32 Samsung NP540U3C-A02UB Speaker Replacement: passo 16, imagem 2 %32
    • Using the metal spudger, scrape away the adhesive underneath the speaker that binds it to the laptop casing.
    • Remove the speaker from the case.
Conclusão
Alejandro
Membro desde: 03/28/22
253 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team C-1, Gurgel Spring 2022 Membro de UMass Dartmouth, Team C-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SCG1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 107
