Introdução
This guide covers how to replace the RAM for the Samsung Series 5 NP540U3C-A02UB.
The RAM provides memory to the laptop while running the operating system and its many applications. Such memory is essential for allowing the laptop to complete many tasks such as loading applications, editing spreadsheets, and browsing the Internet. Damage to the laptop's RAM may result in a slow operating system or crashing. If you are experiencing these issues, see our troubleshooting guide for possible causes and solutions before attempting to replace the RAM.
Free diagnostic programs available via the Internet can detect if crashes are a result of RAM issues, or some other cause. If a replacement is necessary, the laptop uses SODIMM DDR3 RAM running at a speed of 1600 MHz. Ensure that any RAM purchased meets these specifications. Compatible RAM is attached below.
It should be noted that the laptop comes with 4 GB of soldered RAM on the motherboard which cannot be removed. An additional 4 GB of RAM can be added and replaced.
O que você precisa
Remove the following screws holding the case together:
6x 4mm Phillips #00 screws.
3x 6mm Phillips #00 screws.
