Ir para o conteúdo principal
Samsung NP540U3C-A02UB Hinge Replacement
O que você precisa
  1. Samsung NP540U3C-A02UB Hinge Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Hinge Replacement: passo 2, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 2, imagem 2 %32
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Hinge Replacement: passo 3, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 3, imagem 2 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 3, imagem 3 %32
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Hinge Replacement: passo 4, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 4, imagem 2 %32
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Hinge Replacement: passo 5, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Hinge Replacement: passo 6, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 6, imagem 2 %32
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Hinge Replacement, Hinge Assembly: passo 7, imagem 1 %32
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Hinge Replacement: passo 8, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 8, imagem 2 %32
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Hinge Replacement: passo 9, imagem 1 %32 Samsung NP540U3C-A02UB Hinge Replacement: passo 9, imagem 2 %32
    • Remove the two 4 mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Hinge Replacement: passo 10, imagem 1 %32
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Hinge Replacement: passo 11, imagem 1 %32
    • Open the laptop.
    • Use the Opener Tool to gently pry off the plastic piece that is covering the hinges.
    • The hinges and frame of the laptop are made of aluminum; be gentle when removing this section.
  12. Samsung NP540U3C-A02UB Hinge Replacement: passo 12, imagem 1 %32
    • Close the laptop and flip it so its bottom is facing up and the hinges are exposed.
  13. Samsung NP540U3C-A02UB Hinge Replacement: passo 13, imagem 1 %32
    • For each hinge needing a replacement:
    • Remove the three 4 mm Phillips #00 screws attaching the hinge to the display assembly.
    • Remove the two 4 mm Phillips #00 screws attaching the hinge to the base of the laptop.
  14. Samsung NP540U3C-A02UB Hinge Replacement: passo 14, imagem 1 %32
    • Remove the hinge.
Conclusão
Caleb Hunt
Membro desde: 03/28/22
157 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 21
Ao todo: 339
