Ir para o conteúdo principal
Samsung NP540U3C-A02UB Fan Replacement
O que você precisa
  1. Samsung NP540U3C-A02UB Fan Replacement, Fan: passo 1, imagem 1 %32
    • Turn off the laptop and disconnect from the charging cable before beginning disassembly.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Fan Replacement: passo 2, imagem 1 %32 Samsung NP540U3C-A02UB Fan Replacement: passo 2, imagem 2 %32
    • Remove the 1x 4mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Fan Replacement: passo 3, imagem 1 %32 Samsung NP540U3C-A02UB Fan Replacement: passo 3, imagem 2 %32 Samsung NP540U3C-A02UB Fan Replacement: passo 3, imagem 3 %32
    • Gently release the three clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Fan Replacement: passo 4, imagem 1 %32
    • Peel the yellow tape up so it no longer blocks the fan's wires and screw.
  5. Samsung NP540U3C-A02UB Fan Replacement: passo 5, imagem 1 %32
    • Remove the two 2.4mm Phillips #00 screws attaching the fan to the case.
    • Remove the two 6mm Phillips #00 screws attaching the fan to the case.
  6. Samsung NP540U3C-A02UB Fan Replacement: passo 6, imagem 1 %32 Samsung NP540U3C-A02UB Fan Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool, gently disconnect the fan from the motherboard by unplugging the wire.
  7. Samsung NP540U3C-A02UB Fan Replacement: passo 7, imagem 1 %32
    • Remove the fan from the case.
Conclusão
Uma outra pessoa concluiu este guia.
Colby Bolger
Membro desde: 03/28/22
277 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 346
