Ir para o conteúdo principal
Samsung NP540U3C-A02UB Battery Replacement
O que você precisa
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: passo 1, imagem 1 %32
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: passo 2, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 2, imagem 2 %32
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: passo 3, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 3, imagem 2 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 3, imagem 3 %32
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: passo 4, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 4, imagem 2 %32
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: passo 5, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: passo 6, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 6, imagem 2 %32
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: passo 7, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement, Battery: passo 7, imagem 2 %32
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: passo 8, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 8, imagem 2 %32
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: passo 9, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 9, imagem 2 %32
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: passo 10, imagem 1 %32
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: passo 11, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 11, imagem 2 %32
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: passo 12, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 12, imagem 2 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 12, imagem 3 %32
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: passo 13, imagem 1 %32 Samsung NP540U3C-A02UB Battery Replacement: passo 13, imagem 2 %32
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: passo 14, imagem 1 %32
    • Remove the battery from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Alejandro
Membro desde: 03/28/22
253 Reputação
Autoria de 2 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 1,177
