Ir para o conteúdo principal
Samsung NP530U4BL Hard Drive Replacement
O que você precisa
  1. Samsung NP530U4BL Hard Drive Replacement, Removing Back Cover: passo 1, imagem 1 %32
    • Before disassembling your computer, make sure it is powered off.
    • Using the Phillips #00 screwdriver, remove all ten 1.5 mm screws from the back cover of the laptop.
    • Removing these screws allows you to take off the panel on the right side of the laptop.
  2. Samsung NP530U4BL Hard Drive Replacement: passo 2, imagem 1 %32 Samsung NP530U4BL Hard Drive Replacement: passo 2, imagem 2 %32
    • Using your dominant hand, pinch the tab on the back panel to the right and remove it.
    • Using the Phillips #00 screwdriver, remove the two 1.5 mm screws that are under the panel.
    • You are now able to detach the entire back cover of the laptop. You can store these screws in the same area as the others because they are all 1.5 mm, identical parts.
  3. Samsung NP530U4BL Hard Drive Replacement: passo 3, imagem 1 %32
    • Be sure that you are looking at the laptop so that the spine connecting the base to the screen is at the top.
    • When using the plastic opening tool, be careful not to rip or pull too hard to disengage the prongs connecting the back cover to the base. Moving slowly will make this task easier and less likely to cause damage to your machine.
    • Using the plastic opening tool, start in the upper-left hand corner of the laptop and pry horizontally to the upper right-hand corner.
  4. Samsung NP530U4BL Hard Drive Replacement: passo 4, imagem 1 %32
    • Again starting in the upper left-hand corner, pry down vertically towards the bottom left-hand corner of the laptop.
    • You have now disengaged two of the four sides holding the back cover onto the base.
  5. Samsung NP530U4BL Hard Drive Replacement: passo 5, imagem 1 %32 Samsung NP530U4BL Hard Drive Replacement: passo 5, imagem 2 %32
    • Using your dominant hand, grasp the left side of the back cover and gently pull it up. This should disengage the prongs on the bottom and right edge of the base.
    • The right side of the cover has openings that go around the USB ports, the HDMI port, the Ethernet port, the VGA port, and the headphone jack. Use caution when disengaging the prongs around these parts.
    • After completing this step the entire back cover should be separated from the base, and the inside of the laptop should be revealed.
  6. Samsung NP530U4BL Hard Drive Replacement: passo 6, imagem 1 %32 Samsung NP530U4BL Hard Drive Replacement: passo 6, imagem 2 %32
    • All steps following the removal of the back cover should be completed while wearing an Anti static bracelet. This prevents ESD (electrostatic discharge). ESD can damage nearly every part on the inside of your computer.
  7. Samsung NP530U4BL Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 Samsung NP530U4BL Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32
    • Hard Drive (not pictured)
    • Using your dominant hand, unplug the hard drive from its SATA plug. Once unplugged, the hard drive is an independent piece from the laptop.
  8. Samsung NP530U4BL Hard Drive Replacement: passo 8, imagem 1 %32
    • When handling the hard drive, do so carefully. Dropping or banging the hard drive can risk serious damage to the part.
    • Carefully lift the hard drive vertically out of its place.
Conclusão
Uma outra pessoa concluiu este guia.
Kayla Loycano
Membro desde: 03/02/16
889 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 8-1, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-1, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,251
