Introdução
The speaker is responsible for the output of audio from the device. Signs of a faulty speaker could be no or distorted audio. This guide will show you how to replace it properly.
O que você precisa
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Unplug the connector from the hard drive by pulling straight out.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
Using the plastic opening tool, pry up the left speaker and take it out.
Step 4, the last picture should indicate where the speakers are. Oh, and, black bullets.
Uma outra pessoa concluiu este guia.
