Ir para o conteúdo principal
Samsung NP510R5E-A01UB Speaker Replacement
O que você precisa
  1. Samsung NP510R5E-A01UB Speaker Replacement, Hard Drive: passo 1, imagem 1 %32
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Speaker Replacement: passo 2, imagem 1 %32
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Speaker Replacement: passo 3, imagem 1 %32 Samsung NP510R5E-A01UB Speaker Replacement: passo 3, imagem 2 %32
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: passo 4, imagem 1 %32 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: passo 4, imagem 2 %32 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: passo 4, imagem 3 %32
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Speaker Replacement: passo 5, imagem 1 %32 Samsung NP510R5E-A01UB Speaker Replacement: passo 5, imagem 2 %32
    • Untangle the wires attached to the exterior of the right speaker.
    • Lift the tape up holding the wires down to fully release the wires.
  6. Samsung NP510R5E-A01UB Speaker Replacement: passo 6, imagem 1 %32
    • Unscrew the 3.4mm long screw holding the right speaker in place.
  7. Samsung NP510R5E-A01UB Speaker Replacement: passo 7, imagem 1 %32
    • Pull up on the wires circled to disconnect the right speaker.
  8. Samsung NP510R5E-A01UB Speaker Replacement: passo 8, imagem 1 %32
    • Using the plastic opening tool, pry up the right speaker and take it out.
  9. Samsung NP510R5E-A01UB Speaker Replacement: passo 9, imagem 1 %32
    • Unscrew the 3.4mm long screw holding the left speaker in place.
  10. Samsung NP510R5E-A01UB Speaker Replacement: passo 10, imagem 1 %32
    • Pull up on the wires to disconnect the left speaker.
  11. Samsung NP510R5E-A01UB Speaker Replacement: passo 11, imagem 1 %32
    • Using the plastic opening tool, pry up the left speaker and take it out.
Conclusão
Uma outra pessoa concluiu este guia.
Brian Briggs
Membro desde: 02/14/18
529 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 240
