Ir para o conteúdo principal
Samsung NP510R5E-A01UB Display Replacement
O que você precisa
  1. Samsung NP510R5E-A01UB Display Replacement, Hard Drive: passo 1, imagem 1 %32
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Display Replacement: passo 2, imagem 1 %32
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Display Replacement: passo 3, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 3, imagem 2 %32
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Display Replacement, Display: passo 4, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement, Display: passo 4, imagem 2 %32 Samsung NP510R5E-A01UB Display Replacement, Display: passo 4, imagem 3 %32
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Display Replacement: passo 5, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 5, imagem 2 %32
    • Disconnect the black and white cables by pulling up as pictured.
  6. Samsung NP510R5E-A01UB Display Replacement: passo 6, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 6, imagem 2 %32
    • Disconnect the black cable by pulling straight out.
  7. Samsung NP510R5E-A01UB Display Replacement: passo 7, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 7, imagem 2 %32 Samsung NP510R5E-A01UB Display Replacement: passo 7, imagem 3 %32
    • Unscrew the two 4.45mm long screws to disconnect the left hinge.
    • Unscrew the two 4.45mm long screws to disconnect the right hinge.
    • At this point the screen and plastic housing should be completely disconnected.
  8. Samsung NP510R5E-A01UB Display Replacement: passo 8, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 8, imagem 2 %32
    • Using the plastic opening tool, pry open the plastic housing that holds the display.
  9. Samsung NP510R5E-A01UB Display Replacement: passo 9, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 9, imagem 2 %32
    • Unscrew the four 3.55mm long screws that hold the display in place.
  10. Samsung NP510R5E-A01UB Display Replacement: passo 10, imagem 1 %32 Samsung NP510R5E-A01UB Display Replacement: passo 10, imagem 2 %32
    • Disconnect the last cable by pulling straight out.
Conclusão
Dominic Simpson
Membro desde: 02/14/18
245 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 684
