Ir para o conteúdo principal
Samsung NP510R5E-A01UB Battery Replacement
O que você precisa
  1. Samsung NP510R5E-A01UB Battery Replacement, Hard Drive: passo 1, imagem 1 %32
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Battery Replacement: passo 2, imagem 1 %32
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Battery Replacement: passo 3, imagem 1 %32 Samsung NP510R5E-A01UB Battery Replacement: passo 3, imagem 2 %32
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Battery Replacement, Battery: passo 4, imagem 1 %32 Samsung NP510R5E-A01UB Battery Replacement, Battery: passo 4, imagem 2 %32 Samsung NP510R5E-A01UB Battery Replacement, Battery: passo 4, imagem 3 %32
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Battery Replacement: passo 5, imagem 1 %32 Samsung NP510R5E-A01UB Battery Replacement: passo 5, imagem 2 %32 Samsung NP510R5E-A01UB Battery Replacement: passo 5, imagem 3 %32
    • Use the screwdriver to remove the four 3.5mm long screws holding the battery in place. Then carefully pull the battery's connector cable out to remove the battery.
Conclusão
Brian Briggs
Membro desde: 02/14/18
529 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S6-G5, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S6G5
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 2,429
