Introdução
The back case of the laptop is extremely important as it protects the internal components of the device. If the back case were to become damaged, it should be replaced as soon as possible to maintain a proper functioning device. You can follow this step by step guide in order to properly replace the back case.
O que você precisa
Lightly press down on the the back panel and pull away from the back case. The panel should slide away and detach from the back case.
Uma outra pessoa concluiu este guia.
