Ir para o conteúdo principal
Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement
O que você precisa
  1. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, Battery: passo 1, imagem 1 %32
    • Turn the computer off.
    • Disconnect the charging cable from the laptop.
    • Failure to disconnect cable may result in electric shock.
    • Flip the laptop face down on a flat surface.
  2. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: passo 2, imagem 1 %32
    • Slide the left and right switches to the unlock position.
  3. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: passo 3, imagem 1 %32 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement: passo 3, imagem 2 %32
    • While holding the left and right lock switches in the unlock position, pull the battery away from the computer.
  4. Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: passo 4, imagem 1 %32 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: passo 4, imagem 2 %32 Samsung NP36535C-S05US ODD/HDD/Memory panel Replacement, ODD/HDD/Memory panel: passo 4, imagem 3 %32
    • Locate the ODD/HDD/Memory panel.
    • Remove the 1.9 mm screw located on the ODD/HDD/Memory panel with the Philips #0 screwdriver.
    • Slide the ODD/HDD/Memory panel away from the device to remove it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 1,428
