Ir para o conteúdo principal
Samsung NP350V5C-T02US Wifi card Replacement
O que você precisa
  1. Samsung NP350V5C-T02US Wifi card Replacement, Wifi card: passo 1, imagem 1 %32
    • Flip over the laptop so you are facing the backside.
  2. Samsung NP350V5C-T02US Wifi card Replacement: passo 2, imagem 1 %32 Samsung NP350V5C-T02US Wifi card Replacement: passo 2, imagem 2 %32 Samsung NP350V5C-T02US Wifi card Replacement: passo 2, imagem 3 %32
    • Look for the compartment with the Wifi symbol on it.
    • Using the Phillips #1 screwdriver remove the M2.5X5 screw, located beside the Wifi Symbol.
    • Using the plastic spudger, carefully pry the Wifi panel off.
  3. Samsung NP350V5C-T02US Wifi card Replacement: passo 3, imagem 1 %32 Samsung NP350V5C-T02US Wifi card Replacement: passo 3, imagem 2 %32
    • Gently remove the two wires attached to the the Wifi card by using the plastic spudger to pry from underneath the attachment points.
    • Using the #2 Phillips screwdriver, remove the M2.5X3 mm screw holding in the Wifi card
  4. Samsung NP350V5C-T02US Wifi card Replacement: passo 4, imagem 1 %32 Samsung NP350V5C-T02US Wifi card Replacement: passo 4, imagem 2 %32
    • Using you hand, gently pull out the Wifi card.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Duração total: 1,055
