Ir para o conteúdo principal
Samsung NP350V5C-T02US RAM Replacement
O que você precisa
  1. Samsung NP350V5C-T02US RAM Replacement, ODD/HDD/Memory Cover: passo 1, imagem 1 %32
    • Flip the laptop over so that the bottom is facing toward you.
  2. Samsung NP350V5C-T02US RAM Replacement: passo 2, imagem 1 %32
    • Using the Phillips #1 screwdriver, remove the M2.5X5 mm screw to take the back cover out.
  3. Samsung NP350V5C-T02US RAM Replacement: passo 3, imagem 1 %32
    • Using your hand slide the ODD/HDD/Memory panel off in a downward motion.
  4. Samsung NP350V5C-T02US RAM Replacement, RAM: passo 4, imagem 1 %32
    • Locate the RAM in the lower right hand corner.
  5. Samsung NP350V5C-T02US RAM Replacement: passo 5, imagem 1 %32
    • Depress both sides of the lock mechanism at the same time using tweezers to remove the RAM.
    • Since there are two RAMs, remove the other one by using the same method.
  6. Samsung NP350V5C-T02US RAM Replacement: passo 6, imagem 1 %32
    • After removing all RAMs, the empty space looks like this. Then users can install the new RAMs.
Conclusão
Um comentário
Hello,
Thank you for all of the guides. I was curious if you know what the maximum amount of RAM that this laptop can be upgraded to?
On the Samsung site, it says the max is 8 GB, however the Intel site says 32 GB is the max for the processor.
Could the difference be the motherboard?
Thanks!
Will
Will Terfansky - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 985
