Ir para o conteúdo principal
Samsung NP350E5C-A02US Wifi card Replacement
O que você precisa
  1. Samsung NP350E5C-A02US Wifi card Replacement, Battery: passo 1, imagem 1 %32
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Wifi card Replacement: passo 2, imagem 1 %32
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Wifi card Replacement: passo 3, imagem 1 %32
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Wifi card Replacement, Wifi card: passo 4, imagem 1 %32
    • Look for the compartment with the Wifi symbol on it.
  5. Samsung NP350E5C-A02US Wifi card Replacement: passo 5, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
  6. Samsung NP350E5C-A02US Wifi card Replacement: passo 6, imagem 1 %32
    • Gently pry up cover using a plastic spudger or opening tool.
  7. Samsung NP350E5C-A02US Wifi card Replacement: passo 7, imagem 1 %32
    • Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
  8. Samsung NP350E5C-A02US Wifi card Replacement: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
  9. Samsung NP350E5C-A02US Wifi card Replacement: passo 9, imagem 1 %32
    • Gently pull out the Wifi card.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 284
