Ir para o conteúdo principal
Samsung NP350E5C-A02US RAM Replacement
O que você precisa
  1. Samsung NP350E5C-A02US RAM Replacement, Battery: passo 1, imagem 1 %32
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US RAM Replacement: passo 2, imagem 1 %32
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US RAM Replacement: passo 3, imagem 1 %32
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US RAM Replacement, Hard drive and memory stick cover: passo 4, imagem 1 %32
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US RAM Replacement: passo 5, imagem 1 %32
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US RAM Replacement: passo 6, imagem 1 %32
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US RAM Replacement, RAM: passo 7, imagem 1 %32
    • Gently push the lock springs outwards and the RAM stick will rise when it's free.
  8. Samsung NP350E5C-A02US RAM Replacement: passo 8, imagem 1 %32
    • Then, gently pull the RAM stick towards the front of the laptop.
  9. Samsung NP350E5C-A02US RAM Replacement: passo 9, imagem 1 %32
    • Repeat the last two steps for the second RAM stick if needed.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Duração total: 264
