Ir para o conteúdo principal
Samsung NP305E5A-A03US Optical Drive Replacement
O que você precisa
  1. Samsung NP305E5A-A03US Optical Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US Optical Drive Replacement: passo 2, imagem 1 %32
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US Optical Drive Replacement: passo 3, imagem 1 %32 Samsung NP305E5A-A03US Optical Drive Replacement: passo 3, imagem 2 %32
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US Optical Drive Replacement: passo 4, imagem 1 %32
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US Optical Drive Replacement: passo 5, imagem 1 %32 Samsung NP305E5A-A03US Optical Drive Replacement: passo 5, imagem 2 %32
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US Optical Drive Replacement: passo 6, imagem 1 %32
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US Optical Drive Replacement, Optical Drive: passo 7, imagem 1 %32
    • Unscrew the fourteen 9.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the two 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  8. Samsung NP305E5A-A03US Optical Drive Replacement: passo 8, imagem 1 %32 Samsung NP305E5A-A03US Optical Drive Replacement: passo 8, imagem 2 %32
    • Insert the plastic opening tool between the seam of the back panel and the laptop.
    • Slide the plastic opening tool along the seam to loosen the back panel from the laptop.
    • It may be difficult to slide the plastic opening tool along the seam, so you may have to apply some force.
  9. Samsung NP305E5A-A03US Optical Drive Replacement: passo 9, imagem 1 %32 Samsung NP305E5A-A03US Optical Drive Replacement: passo 9, imagem 2 %32 Samsung NP305E5A-A03US Optical Drive Replacement: passo 9, imagem 3 %32
    • Remove the Back Panel by lifting it towards you.
    • It may take some force to remove the Back Panel.
  10. Samsung NP305E5A-A03US Optical Drive Replacement: passo 10, imagem 1 %32 Samsung NP305E5A-A03US Optical Drive Replacement: passo 10, imagem 2 %32
    • Remove the Optical Drive by sliding it away from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Kris Stobbe
Membro desde: 10/30/16
585 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 5-7, Williams Fall 2016 Membro de Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 317
