Ir para o conteúdo principal
Samsung NP305E5A-A03US Battery Replacement
  1. Samsung NP305E5A-A03US Battery Replacement, Battery: passo 1, imagem 1 %32
    • Be sure to power down your laptop before replacing your battery.
    • Turn your laptop upside down so that the battery component is facing you.
  2. Samsung NP305E5A-A03US Battery Replacement: passo 2, imagem 1 %32
    • Place your thumbs on the lock tabs.
    • Slide the tabs with your thumbs in an outward direction (in the direction of the arrows).
    • You should hear a click when you properly slide the tabs all the way.
  3. Samsung NP305E5A-A03US Battery Replacement: passo 3, imagem 1 %32 Samsung NP305E5A-A03US Battery Replacement: passo 3, imagem 2 %32
    • Pull the battery out of the laptop towards yourself to safely remove the battery.
    • If you are discarding the battery, please do not throw it away in the trash. Instead find a local battery recycling facility that will not damage the environment.
Conclusão
3 outras pessoas executaram este guia.
Kris Stobbe
Membro desde: 10/30/16
585 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 5-7, Williams Fall 2016 Membro de Baylor, Team 5-7, Williams Fall 2016
BU-WILLIAMS-F16S5G7
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 517
