Ir para o conteúdo principal
Samsung NP300E5C Optical Drive Replacement
O que você precisa
  1. Samsung NP300E5C Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Optical Drive Replacement: passo 2, imagem 1 %32 Samsung NP300E5C Optical Drive Replacement: passo 2, imagem 2 %32 Samsung NP300E5C Optical Drive Replacement: passo 2, imagem 3 %32
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
  4. Samsung NP300E5C Optical Drive Replacement: passo 4, imagem 1 %32 Samsung NP300E5C Optical Drive Replacement: passo 4, imagem 2 %32
    • With the 4 mm Phillips #8 screw removed, firmly but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  5. Samsung NP300E5C Optical Drive Replacement: passo 5, imagem 1 %32
    • Remove the 4 mm Phillips #8 screw to the left of the hard drive using a Phillips #00 screwdriver.
  6. Samsung NP300E5C Optical Drive Replacement: passo 6, imagem 1 %32 Samsung NP300E5C Optical Drive Replacement: passo 6, imagem 2 %32
    • Using your fingernail or spudger to gently pull your optical drive out.
Conclusão
3 outras pessoas executaram este guia.
aliahsan95
Membro desde: 09/23/15
937 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 10-13, Williams Fall 2015 Membro de Baylor, Team 10-13, Williams Fall 2015
BU-WILLIAMS-F15S10G13
Membros da 3
Autoria de 4 guias
Um comentário
Great video, simple steps to follow, very good, thanks.
Chris Hughes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 2,224
