Ir para o conteúdo principal
Samsung NP270E5E-K03US RAM Replacement
O que você precisa
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: passo 1, imagem 1 %32 Samsung NP270E5E-K03US RAM Replacement, Battery: passo 1, imagem 2 %32
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: passo 2, imagem 1 %32 Samsung NP270E5E-K03US RAM Replacement: passo 2, imagem 2 %32
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: passo 3, imagem 1 %32
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: passo 4, imagem 1 %32 Samsung NP270E5E-K03US RAM Replacement: passo 4, imagem 2 %32 Samsung NP270E5E-K03US RAM Replacement: passo 4, imagem 3 %32
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: passo 5, imagem 1 %32 Samsung NP270E5E-K03US RAM Replacement: passo 5, imagem 2 %32 Samsung NP270E5E-K03US RAM Replacement: passo 5, imagem 3 %32
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: passo 6, imagem 1 %32
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Golden
Membro desde: 03/23/17
353 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 1,083
